dcdman67
Active Member
Hi. After a few months of working on our Dart, I finally got her up and running. I went to fill her up, put 10 gallons in a mostly empty tank, and the nozzle clicked off and fuel started to overflow. I took a look under the car and fuel seems to be leaking from the rubber lines towards the top of the tank. I took a look at the manual, and it seems that there is a canister that needs to be replaced?
Has anyone removed and replaced this canister? If so, how easy/difficult is it?
Thanks in advance!
Thanks in advance!
