How do you explain the lack of holes for the "swinger" emblems on the 1/4 panels? That's 70 only. Also this car has the emblems on the fender, that's 71 up. If its really a 70, that side trim is mounted with studs, 71 up is double sided tape. Everything points to the TITLE and FENDER tag from a 70, but so far no confirmation of those numbers on THIS body
Not entirely true! Both of my ‘71’s have side trim mounted with studs on the body, not tape.
maybe 1 out of a million just loved the 71' trim so much they just had to put it on their 70'. stranger things have happened.
another way to check is the 4 vent tubes on the side of the fuel tank and the vertical vent tube in the trunk or a hole in the trunk extension for a vent tube to mount to. all the pictures are so close up its not easy to tell anything really.
the trunk gutter looks like there is some rot there so a VIN may be illegible there.
Doesn’t appear to have the vent tower in the picture of the trunk. Also, not all ‘71’s got that emissions control deal
