jonn6464
1970 Duster
oooooh metalflake! and maybe some lace too
Dang, that would be too pretty to race!
cool, it'd put the competition at ease.Dang, that would be too pretty to race!
looks nice! what size wheels/tires are you running? Also, do you think the rear sway bar would clear a 9" rear end?Did I mention how much wet sanding sucks?!
4 passes with 1000, 1500, 2000, 3000 grits.
But, it is worth it, when it's buffed out.
I'm using Meguiars 110 & 210 this time.
Normally, I'd use their 105 & 205. So far, very happy with the new formula.
So far, I've done the deck lid, tail panel, and tonight did the drivers quarter panel.
View attachment 1715759218 View attachment 1715759220
Yes, i have a ford 9".... really!? that long of a leadtime? yikesTires are 245/45R17 in the front and 255/50R17 in the back.
I don't think you'd have any problem with the sway bar in any rear end. But, I'm not familiar with the 9". Are you talking Ford 9" or MOPAR 9 1/4"?
You can sort of see better here...
Firmfeel Mopar Suspension and Steering
If you go with this sway bar, do not be in a rush. Took me like 12 or 13 weeks to get it.
I do have the Plymouth grill logo that still needs to go on. Plus with the radiator behind it, I think it will add some depth. And the bumper running parallel underneath should helpto me it needs something more, maybe something attached to the front of the mesh (bolted from behind). it looks like the grill was broken so it was cut out and mesh stuck in there to fill the gap (no offence). so if something was fitted to the mesh it could look 'floating' as the black mesh kind of disappears. it wouldn't need much.
neil.
yeah, the logo may be just enough to finish it offI do have the Plymouth grill logo that still needs to go on. Plus with the radiator behind it, I think it will add some depth. And the bumper running parallel underneath should help
A while ago I made a back-lit grill logo (but need to add 1 more LED in the middle), so I'm still deciding if I should go with that or the original black/chrome piece.yeah, the logo may be just enough to finish it off
