If the bushings are not split which I imagine is where this
question comes from, take the bar out, lube the hell out of
it and wrestle them on close, when you get within an inch or
so of final location use the provided grease for the poly bushings.
They are fun, but not quite as fun as say freeing up stuck brakes
or putting headers in....
The originals were split so I split the new ones the same way. Getting them in the sway bar bracket is going to be be a btch. Are saying force the poly bushing over the end of the sway bar after its installed in the bracket mount ?
