rgreule
I wish someone sold turbo kits for A bodies.
thats why i just made mine.. then you can put the turbo or turbos where you want.. and its just cool to make it your own...
got the care epoxy primed the other day... the entire inside and underneath have been por 15'd... 9 inch is all narrowed, ready to start the rear suspension setup and the roll cage in the next little bit.. will post pictures as i go.
that sounds like a sweet setup.. im in the process of oredering my cam from bullet and my pistons from diamond.. i plan on running 11.5.1 compression.. should be perfect for my setup, especially since it is on e85..
http://www.yellowbullet.com/forum/showthread.php?t=520082
pretty impressive 11.5.1 setup
im just going to do flat top pistons.. with a .040 gasket it makes is 10.2.1.. so if wanted i can raise/lower with a different gasket.. the reason for the compression is my weeny little 331 inch motor will need some bottom end and some ummffff to get going.. its gonna be a pretty high winder with that little 3.25 stroke..
i was thinking about going with a a2w but its going to be a street car that gets driven alot and i dont want to have to deal with draining it and re filling it all the time.. if it was a strict race car then i wouldnt mind it..
if i run into problems then i will do meth.. but im pretty possitive that the e85 will be just fine.. im not going for max numbers either.. well yet any way..
