70 Swinger front tire?
70net440
yreka, ca
Anyone running 235/60r14 tires on the front of a 70 Dart Swinger. We need to put some new shoes on my son's car. Currently it has 225/60r14 on the front, but Goodrich T/A's are the only tires made in that size anymore. I don't have the car here to swap one of the rear 235/60r14 tires to the front to see if there will be clearance issues.
If you run 235/55/r14 it should be the same outside diameter. Slightly lower profile and 10mm wider.
