700 cfm holly
66 Barracuda
So I read everyone discussing eddys and hollys. I have decided on the Holly. So which one. Most people seem to discuss the 650 and 750. What about going in-between? "700" I am building a mostly street driven car but would do some track time ocassionally. All articals I've read have left me leaning toward 650 mechanical secondaries. Help?
-1966 Barracuda
-1978 360ci
-original heads with smog ports blocked and valves 2.02 int and 1.88 exh
with heavy springs
-cylinders .030 over with KB 107's
-Lunati Voodoo cam 268/276 Rpm range 1800-6200
-old torquer 2 single plane eddy intake manifold.
-904 trans / 2500 stall
-8 3/4 sure grip rear end
-355 gears
-225/60/15 tires
-standard mopar electronic ignition
Lunati cams says 700 cfm. but I am lacking the headers in there setup and am running a single plane intake vs dual . A have managed to successfully install 340 hi po manifolds. Didn't want to deal with headers.
Am I right thinking 650?
Maybe even 750?
The way I see it, being a street driven ride that isn't turning a lot of RPM, I'd run with either the 650 or 700 cfm double pumpers. I think you'll be fine and really enjoy the snappy throttle response.
