For Sale is a Black floor shift steering column for Power Steering. Has the separate interlock safety column. I took it apart media blasted all pieces, them coated everything with Transtar matt black. Bearing were inspected and repacked. Turn signal switch is original as they are much better than the aftermarket ones. Ignition key cylinder is new as is the ignition switch assembly. Also the steering box slip joint was rebuilt. comes with the floor plate bolts and the three mounting studs and bolt. Fits 70-76 A-bodies. This one came out of a 72 340 4 speed Duster with power steering.
$350.00 Plus shipping
