French demon
Hello folks
In the '71 Dart/Demon FSM engine wiring harness, there is a darkblue wire [J2E-18DBL]
This wire is connected onto the idle stop solenoid of 340ci engines only.
OK. Now the question : is this J2E-18DBL wire present in ALL Dart/Demon engine harness? Even of those equipped with a slant?
Here's a picture of my ballast resistor and two blue wires are plugged onto the left connector.
According to the '71 FSM wiring schema above, there should be only one blue wire connected to the ballast resistor.
I suspect a precedent owner to have cut and rerouted the J2E-18DBL wire (unused with a non-340ci engine) to the ballast resistor.
As it comes from a splice, this wire is useless and doesn't disturb the ballast resistor function, but just want to know what's this extra darkblue wire.
François
François
