[SOLD] 71 Dart Swinger
68383GTS
East Peoria,IL
71 Dart Swinger Roller NO ENGINE or TRANS. 8.8 rear end.One owner car until 2015. Fairly clean car..Location East Peoria,IL. $4300.00 firm.
What was the OEM engine?
Can I get under hood/trunk pictures?
The original owner had Ziebart spray under coating on the bottom of the floor pans.They also sprayed the inner fenders. I scrapping it off one inner fender. The plan was to paint under the hood. One pic is before I sold the engine. The other is now as it is.
If you dont want the 8.8 rear end. I would take $4000.00 for the car.You can bring a rear end we can put under it or some caster wheels.
If you dont want the 8.8 rear end. I would take $4300.00 for the car.You can bring a rear end we can put under it or some caster wheels.
Trunk is rustfree. Worst of the car is the drivers quarter panel. It will need some work.Passenger quarter had some surface rust and I stripped it down behind the wheel and primered it and sprayed some yellow on it.
Also have new leaf springs,brake line kit,small block conversion mounts,suspension rebuild parts,and a disc brake conversion kit with 11" rotors and tubular A arms,shocks. $1500.00 in new parts.
