hpmopar
- Joined
- Oct 6, 2006
- Messages
- 93
- Reaction score
- 26
I bought a quicktime bellhousing for the 440 to put back in the 71 Demon.
Do you have some suggestions on the z-bar set up/mods I need to do to make the schumacher headers fit better. I saw TTi makes a modified z-bar
Also the clutch fork I was using was a stock A body 12 1/2 inch lenth. Should I use a shorter one?
There was a plate they welded the to the ball stud spacer bracket and set it 1 1/4 inches back and an 1/8 inch farther out.
The original setup w/ the 413 and B body Bell housing pulled the z-bar back on an angle towards the firewall.
Anyone.....
Anyone.....
