Demon Bundy
Member
I have a 71 Demon with a Duster tail panel that I'm change back to a Demon tail piece, will the Demon taillight lens work with the Duster housing or do I need to get Demon housing ?
Yes they are different you cannot use duster housings for Demon lenses. I have them to compareThanks, are 71 Duster housings different from 71 Demon ?
Can you give a part # off the housing ? ThanksYes they are different you cannot use duster housings for Demon lenses. I have them to compare
From the count in the pictures I have 40 Duster and 10 Demon. Probably more stored at different locations on the properties
