Having an overcharging problem, here's what I know so far.....
fast idle, nearly 16v
reg idle, 14.3ish v (lights on)
disconnect v reg, 12.5ish v
reconnect v reg and disconnect green wire @ field 12.5ish v
any above idle rpm sends it straight up toward 18v and pegs the gauge.
all readings above done with dvom to verify gauge operation
all grounds solid to v reg etc.
no shorts to ground in green output wire
just to be doubly sure, overlayed new wire from v reg to alt to bypass green wire, no change in overcharge condition
swapped in different alternator, no change
swapped a few v regs, no change
installed relay in system tapped into the blue wire and fed from the b+ of the starter relay, no change
getting good near battery voltage at blue wire of reg
more info.... have done amp meter to volt meter conversion with bypass from alt b+ to starter relay
as well, I did the bulkhead connector bypas on that cicuit
also, I have completely replaced my stock gauge cluster with autometer gauges so nothing in there is stock any more
I currently have the pin connector that use to feed the factory printed circuit cluster tapped up and isolated under the dash, and tapped into the harness down below for signal bulbs...
wondering if not having a "voltage limiter" in the system any more due to the replacement of the printed circuit cluster could have anything to do with this?
also, in my research, it seems I should have a dual balast resistor? this car only has wiring for a single, though I placed a dual there with only one side wired up, should I be duplicating the wiring diagram to add the "compensating resistor" into the system? and could this be the problem?
please help, thanx in advance, this is driving me nuts, and I wanna be out there cruising, not fearing my battery will explode aaagghhhh!!! lol
