Darthomas
Ashamed to be seen in foreign cars
Must sell due to divorce.
Located in Chicago.
Stored 20 years.
Never wrecked.
Built in Windsor Canada.
Had a darn Rochester carb on it!
Originally 318-904-7 1/4.,
white with black vinyl top.
Original Tuff wheel, power steering.
Was sad weak 10 inch drums, now
manual discs from 74 Dart, 10.5 inch van brakes in back.
Oversize torsion bars from that place in New Jersey so it corners FLAT, like a go cart.
Addco sway bars front 1.25in and back .75 inch.
1986 Corvette gas shocks in front, Ford 1.5 ton truck gas shocks in rear.
Custom drive shaft with conversion u-joint for Detroit-to-Spicer yokes.
Axles shortened and splines re-hardened
by Strange Engineering in Evanston.
(Back when you couldn't buy axles for the narrow rear end)
Factory air worked when last driven.
Large wheel bolt pattern, Mopar 15 inch flat black police rims with silver trim rings and police ventilated dog dish covers also dressed down to half-flat, half chrome look.
Fiberglass front fenders, one new passenger side fiberglass fender included.
Actual AAR block 340, with competition cams 262 degree,
1973 Thermoquad, 10.5 : 1 compression,
built by Van Senus Speed in Hammond Indiana.
Factory exhaust manifolds. Crossover pipe between duals. Exhaust system new when car parked.
Bright yellow with all chrome trim dressed to flat black.
Recaro seats from 1978 VW sirocco reupholstered to match 71 dart design,
need doing over.
Center console from some early 80's GM 2- door that fit perfectly.
Black vinyl roof changed in 1987, needs it again.
One owner since 1980.
Stored in bone dry garage since 1995.
No recent photos, honest answers to any questions.
Needs trans rebuild. Trans built by Cope Racing Transmission. Drives well but 1st gear must be manually selected from stops.
Quarter panels replaced in 1986 letting go at bottoms. Wheel wells too.
Underhood fender wells average rust.
Parked it rather leave it outside to get worse.
Blaupunkt stereo with hidden giant amp from mid-80s and 2 hidden 12 inch subwoofers behind rear seat under rear deck.
One rechromed rear bumper included.
Will be looking for photos to upload.
Asking $6000, because it's been respected and cared for since 1980.
Located in Chicago.
Stored 20 years.
Never wrecked.
need doing over.
