Hello
I was out doing some work on the ignition system of my 71 valiant 225 slant six trying to resolve a misfire it's been having. I replaced the cap, rotor, and plug wires. When I went to test fire the car it didn't want to start and chuffed a little. I went back and double, triple, and quadruple checked the firing order and it looks right. 1-5-3-6-2-4
I used this as reference....
I used these parts....
Standard Motor Spark Plug Wire Sets 29613
https://www.summitracing.com/parts/SMP-CH410
Standard Motor Distributor Rotors CH303
So I would crank a couple seconds... wait a while to let the starter rest. Then crank a couple seconds more.
Now the starter won't engage the flywheel and just spins. There are no grinding or clicking noises.... just the electric motor spinning.
Did I just destroy my starter or is there something I can try first? This couldn't have possibly happened at a worse time because I am starting the fall semester in 4 days.
