Scubakuda19
SOLD
Buffalo, NY
38700400
2780930-340-5
Block cast date 1-14-71
MH340R
The engine is a cast crank engine, and it spins easily with a wrench. The cylinders show alittle rust from sitting. It has a oil pump, windage tray , oil pan, timing gear and cam. It had a set of 318 heads on it which I included pics of. It also had a cast intake and a carb you can have with it. I'm located in Buffalo, Ny and pick up only.
Buffalo, NY
38700400
2780930-340-5
MH340R
