[SOLD] 72 360 $500
abdywgn
dismantler
Darien, Illinois
72 360 short block(crank,rods,pistons,cam,lifters,timing chain,front cover,balancer,oil pan,oil pump with pick-up), pair 587 heads,assembled with rocker arms,shafts,pushrods and head bolts.Removed last summer from a running,driving car.Short block assembled,heads removed. Appears to be std bore,no oversize markings on pistons.Parts in Darien,Illinois, pick-up only.Thank-you for the ad.
available
Hey, I noticed this ad a few days ago, and it interested me. Do you still have it? I'm not up to speed with what the "587" heads are from, do you know what engine their off of? Please let me know when you can and I would greatly appreciate it man.
Chris
1.88 intake valve,1.60 exhaust valve 340-360 head. Have a set on my 73 360.Listed as being used on 73-74 and again in 76. some have holes drilled in the pads below the exhaust port for AIR injection. they would need to be plugged if using headers. these are solid,undrilled from the factory.
