340plot
the bushy bush
i have a car that i just picked up, and with the scamp project, i think it may be wise to let someone else take this one. it is a real solid car. 318 auto on the column. needs a coil. car starts, and then coil gets hot and shuts off.
also comes with a 69 340, 205 j-heads, it is 30 over. pistons are trw 12:5 to 1 milled down to 10.2 to 1. has huge cam, oil pan. forged crank is perfect. as is the cyluinders. this engine just needs to be put back together. also comes with a 727 that i just got back from the trans shop, and it brand new inside, with 3500 stall converter. i have the cast iron manifold for the engine, but no exaust manifolds. car comes with headers.
the body is solid minus the driver side quarter. it did not have rust, but was backed into, so they pulled the dent and bondoed. other than that, i can not find any bondo in the car.
car is located 30 minutes from martinsville international speedway in va.
free and clear title for the car. thias is a awesome car to drop the 340 into to make a nice street monster on pump gas
