[SOLD] 72 Dart with 500 CI and BDS blower for sale
kjunhemi
South Louisiana
Rating - 0%
0   0   0
Selling for a friend
1972 Dodge Dart. It has a 70 grill and bumpers and the Paint is Tangerine Pearl. Engine is a 500 CI stroker 8:1 compression motor built by Southland Performance with BDS 871 blower system 7 LBS boost, Edelbrock aluminum heads, Comp roller cam shaft .691/.691 gross lift 254/260 duration @ .050 Comp roller rockers and push rods, forged crankshaft, JE pistons, Manley H beam rods, Clevite bearings, Melling oil pump, Moroso 7 quart 7” deep oil pan, MSD ignition, pro billet distributor and billet 160 amp alternator, 2 Quick Fuel 850 carbs, TTI ceramic headers and Mahaffey Motorsports aluminum radiator with dual electric fans. Engine cost $17,000 plus The engine dyno showed 722 corrected HP @ 6500 RPM and 715 corrected TQ @4500 RPM. Transmission is a 727 with 10” A1 converter and a Hurst Quarter Stick shifter. Rear end is a Moser Dana 60 with a Detroit Locker unit with a 4.10 gears and mini tubbed. Suspension is an RMS Chassis set up with Alterkation coil over K member with power rack and pinion steering. Brakes are Wildwood 4 wheel disc with hyraboost power assist. It has a Flaming River tilt steering column and wheel. The wheels are Billet Specialties 18” tires are Mickey Thompson Sportsman S/R radials 18x26x8 front and 18x30x12 rear. Gauge set up is a custom Rocky Mountain dash with Autometer Super Comp gauges. All new Ron Francis wiring system installed. Asking $37,500 OBO partial trades accepted. Car is located in Houma LA.
That think has to be squirly on the street. Any quarter times?
It has never been run at the track. It drives pretty good on the street. It gets driven to some of the cruises that are an 1-2 hours drive away.
Boy that is a work of art ! Built for performing as well as a stunning look ! A little out of my price range ! Good luck with the sale !
Cleaning and polishing getting ready for cruise nights!
