knote72
Stupidity is not unilateral, we all pay the price
So I talked about this on a couple prior threads, but 2 weeks ago I went over to Boise and brought home a 72 Demon as my project car. For $1500, it's got:
And now it's an Oregon car
- Slant 6
- 3spd auto
- 7.25" rear end (has the oddly shaped diff cover with the 9 bolt pattern)
- New sway bars (included, but not installed)
- Hotchkis tie rods
- KYB shocks all round
- Aftermarket strut bars
- Tubular control arms (brand unknown)
- Aftermarket brake cylinder and booster
- Drilled/slotted rotors in front
- Swap the slant for a 340 and find a V8 K-member (may keep the slant for a future project, idk yet). Have plans for alum. heads+intake and a full blown sequential efi setup (edelbrock has a full kit, it's a bit spendy but not too far outta reason considering it's one of few non-TBI efi systems on the market).
- Swap the 904 for a 5-6spd manual, right now the main candidates are Passon's 855 and the Tremec T56 (anyone in the Pac Northwest wanna buy a 904?). The 855 is direct OEM fit, no tunnel mods, but the Tremec is readily available. Thap also means swapping the steering column for a non-auto one.
- Swap the 7.25" rear for a 8.75" and a sure grip (figure 3.55 is a nice round gear ratio to put it close to daily drive-able). Could I make a few bucks selling the 7.25", or is it basically junkyard-bound?
- Stock radiator is toast, half the fins in the first row are gone completely, so a new alum. radiator is in order. Also gonna drop the belt-driven fan for a comp-controlled twin-electric. Between electric fans, new stereo system and the efi system, there's gonna be quite a bit of power draw so it'll need a better alternator. I'd imagine this also means a lot more electrical work than I realize..........
- Came with a front bench seat, but I'll instead go for two buckets and a woodgrain center console around the shifter.
- Depending on how much vacuum I'll generate with the engine setup, I may dump the brake booster and go all discs.
