knote72
Stupidity is not unilateral, we all pay the price
Clearly a brand new forged crank can be found, but looking in the $800 rangeOk so a 318 or 340 forged crank shouldent be too hard to find
Unless your planning on high HP and a stick shift. The shock loading from running a high HP V8 with a standard shift can break the back end of the crank if its cast.
Yeah I know that for a street engine a cast crank will do and about half the price, I just first wanna see if this one can be saved, and if it's still cheaper than buying a new one. I got it in an electrolysis bath right now to pull off as much rust as is safely possible Rust removal by electrolysis
Yes later model. 489 considered to be best. An A body most likely would’ve came with a 741.I'm looking at a 8-3/4" for $400, and I wanna be sure it's really for an A body. The 489 3rd member is the later model unit, right?
I was led to believe the early axles had the 741 and at some point after the late 60s switched entirely to the 489. What exactly is the difference between the two?Yes later model. 489 considered to be best. An A body most likely would’ve came with a 741.
52 5/8” small bolt pattern wheels. Dustin
In the article Dustin linked:Actually 52 5/8 is housing flange to housing flange, that number stays the same regardless of what axles you use.
Wheel mounting surface to wheel mounting surface (“drum to drum”) the SBP axles are 57 1/8”, if it’s been converted to BBP then ~57 13/16”.
If you need to check out an axle, most of the 8 3/4 dimensions are listed here. Both housing flange to flange and drum to drum measurements-
An accurate 8 3/4" rear axle width list
The 741’s were around until ‘72 in the A-bodies at least. My ‘71 Dart has one and it was the original.
The 741, 742 and 489 have different pinion diameters. 741 is the smallest. The 742 is the next largest, then the 489. The “which is stronger” thing is more complicated though because the 489 has a tapered pinion.
"The two Sure Grip types can be interchanged between the carriers if the matching differential axle bearings are retained. The outside diameter of the cups are the same between the '741'/'742' and the '489'; the inner cone differs. "
So what I'm drawing from that is as long as I keep hold of the bearings I can swap the different diffs. My question is, what about the different pinions? Like the carrier bearings, can they too be swapped? That part is still unclear
Yeah only spirited drives here, plan on staying under that 500hp mark. I do plan on a sure grip no doubt, and did plan on 3.55 gears, but I guess I can see how quick it'll wind up on 3.23FYI 741 and 742 are plenty strong for a light A body IMHO unless your planning on some serious dragging. 489 requires a crush sleeve or crush sleeve eliminator when you rebuild. 741, 742 do not. All 3 can use the same limited slip. Its interchangable between all 3.
Got a thread already on that?I am doing a 408 stroker 4 speed. 742 sure grip 3.73 gears. I prob wont break it. They are way overdesigned.
