Paladin06
OK, I had to lower the steering column in order to remove/install the instrument cluster. When I went to position the column and install the retaining bolts under the dash I noted the shaft and moved (slid down) and now the lower column cover is hitting the ignition key removal lever. How is this possible?
Please advise!!
Please advise!!
