Dusterdude72
IN MOPAR MUSCLE MAGAZINE
so....before long I will being hooking up the wiring in my duster but before I do ...I would like to go over everything so i know i have everything i need and that there are no surprises.
here is a run down of what I have.
1972 duster
318,904 auto
bought the car as a project last year and was missing alot of parts and I managed to pick up a firewall forward wire harness from a member that I am going to install.
The harness came with all factory plug ends,voltage regulator,2 ballast resistors and some relays.
my battery has been relocated to the trunk so all I have is a power and ground wire in the engine bay for the battery but no battery.
any diagrams or detailed pictures of someones wiring would be great.
I want to make sure I am not missing any electronic plug in components or anything and i want to make sure I know where i need to run all my wires too....such as where to run my power and ground battery cables and if I am suppose to splice off my power to a distibution block or not? and what wires are alt wires and what wires are distrib wires,oil wires,temp wires.
basically a hole run down....hope you guys get the idea of what Im trying to accomplish and thank you in advance!
1972 duster
318,904 auto
