[SOLD] 72 Duster
mi72duster
Mentor, OH
I hate to do this but I need to sell. I started this project 5 years ago. This a /6 conversion to a balanced 360 clone with less than 2000 miles on the rebuild. 904 transmission. I will be more than happy to email all the engine specs with part numbers used. LA block bored .40 over, KB167 pistons, comp cam 20-223-2, duration 268/280, lift .477/.480, 6 qt Milodon oil pan, windage tray,RHS Mopar Indy 360 X heads, ARP head bolts, roller tip rockers, clear powder coated Edlebrock Performer manifold, Holly 650 double pumper, 1 " carb spacer, Hooker headers, Mopar Performance mini starter. Also have a drum to drum 8 1/4" sure grip that I was going to put in. I'm not going to bs anyone...it needs rockers on both sides back of the doors, rear passenger side floor pan before you put in the 8 1/4". Trunk pan is solid. Legendary front seat cover put on 2 summers ago. Headliner is perfect. Original jack and stand.I have some new parts that go with it....new tail light gaskets, new heater core.
Located in Mentor Ohio 44060
I need to get $5,500...that's less than i have into the engine alone.
Ok so I feel like a real idiot. The frame rail is in great shape. It will eventually need a passenger side rocker from the door back and a passenger side rear floor pan.
