I have a Petty Blue 72 Demon I am wanting to sale or possibly even trade. I will add pictures this evening.
72 Dodge Demon, Car currently has a 318 in it but is originally a 6 cyl. Auto, 7 1/4 rear end, drum brakes, Car is a Petty Blue which appears to be original color but looks like it has had a paint job years back. Car is a column shift auto, with bench seat,Car does not run, One rear spring is from another year and does not fit correctly, Interior color is blue, came with black vinyl top, Very plain car with very little options. As for the body, it will need floor pans replaced, trunk pan repaired or replaced, lower qtr panels look in decent condition and may not need replaced, upper qtrs in good condition, rocker panels are in good condition, front fenders are not rusty, but will need a little repair due to dings/small dents, hood is in good condition, roof in OK condition but does have a hole/cut approx 5" long that will need repaired of replaced, I have another roof that goes with car, Doors have no rust, trunk lid has rust along rear lip but can still be used, I have an excellent rust free deck lid for sale separately, rear tail panel is in good condition, rain gutter has a little rust through at tail panel, Frame rails look very good except front DS will need a repair/patch where the frame rail meets the cross member, DS inner fender needs repair at the battery tray but every where else is very good with no rust. Interior will need to be restored, most everything looks to be there but may be missing a few small items here and there, Car is a good car to build or build drag car. Car is rolling and does not run. I have never checked to see if it would turn over or run. Missing Radiator and a few other small items, No drive shaft, no key, or ignition switch, DS window regulator is not attached to the window and does not stay up, door lack missing in DS door, I try to be overly honest so you don't receive something you did not expect. Car will need to be picked up in Covington, Ga or I can deliver for additional fee.
[email protected]
[email protected]
