72 Pro Street Dart
demon1515
dirty south GA
the day i brough it home!
A litlle art of what it should look like when finished,
parts start showing up!
Original Mopar Tuff steering wheel + addapter "Hard pice to come by, and not cheap"
Good used front lower balance, bumper guards deleted
Manual aluminum steering box "real light unit"
Mancini Racing billet front motor plate, fluid damper harmonic ballancer, hurst competition shifter, custom disc brake front conversion i pice together with wilwood parts and RX-7 rotors
Eagle rods with arp2000 bolts for the 440 big block engine "check em up in comparation with the 2jz rod!
4 speed new procces mopar crash box! "SWEETTT"
Eddy Torker 440 intake and B1 big block valve covers
440 Source SFI billet flywheel
440 Source billet 1/4 inch gridle and main studs assembly with windage tray and billet rear main seal cap
1968 HP2 mopar big block 440 engine and Lakewood scattershield
3.73 gears Dana 60 diff
Stick **** pedal assembly
Car Tool 1/8 inch contoured subframe connectors specially build for the Dart
I redrill the factory 5x4 front hubs and use RX-7 front rotors, the calipers are wilwood 4 piston (not installed yet) but prety easy to do by just fab a 3/16 brackets that bolt it on the spindle, weld 2.0 wheels and 165/80-15 street tires, this is a custom brake that really works and cheap less than $200 for it and my work fabricating the setup, it will use stainless braided brake lines.
A litlle esthetic update
a change in the grill from a 72 to an older and better to my tastes 71 front grill and chrome trim deleted
before
after
More parts showing up
Comp Cams bumpstck
Comp Cam lifters
Pro Comp Billet Dizzy (Australian) :shock:
I score cheaplly a set of TTI 2 inch primaries underchassis headers for A-body, they are sweet! 8-)
SOME minitubing manual steering box and front end love,
MINITUBING, this is a very easy one to do, but it took me about 4.5 hrs. per side.
Manual steering box with no adapter whatsoever very easy from power to manual!
SOME FRONT SUSPENSION LOVE, still need to install the new 90-10 drag shocks,
Looks like you got it rollin and looking nice. Love the drawing, looking forward to watching your progress.
Not really, i parted out my race 2jz 1000 hp celica, to pay for some of my daughter college and have some left to play with this cheapper project!
Here is a picture of my celica!
YES IT GOT A MOPAR 8.75 UNDERNEATH!
I am debating on doing a custom 4 link set up for it or leaving it leaf springed still dont know i will spend almost the same with the complete caltrack setup or doing it 4 link myself, what you guys think?
In one hand the car will have a better rear suspension and in the other hand it will not loose its stock suspension status, still dont know i think when i get to that point i'll deside!
Change the intake, victor single plane intake, and with the sale of the other intake it is dirt cheap so i got to have it!
Here is a side by side picture of the 2!
holy **** man your parts are comming along nicely im jelous looking great man
Nice work.I like the 4 link idea.Gives ya better axle control and easy to adjust the suspension. I had a ladder bar set up in a duster and it was a rough ride to say the least.
Very nice! Looks like the leaves are a big battle lol. Do you still have front fender chrome for the Demon? If so pm me.
