As much as a loudmouth, I can be. :I can't remember how I pulled off the trunk strip 15 years ago. How to find the right one ?( and witch section. ,should be applied to sheet metal with 3m yellow?)
Newer 3m in black doesn't show as bad as yellow.
How the OEM gasket/weather strip is properly positioned has been detailed with pics in at least 2 earlier threads. Bird mouth to outside, longer is the lower.
