67Dart273
This may or may not be a 72, it is in a 72 Scamp. Had it fired yesterday, have not driven the car. Does not idle well probably needs carb work. Showed some oil, no idea how long it's been sitting. Can run a compression check, and probably will later Sounds like it's "on" all 6 cylinders.
This is complete from fan, pulleys, etc. No transmission.
CHEAP $50.00. If I'm in a good mood it might even be free.
Located in Coeur d Alene, ID 83814.
I don't see any way to ship this unless you can make some arrangements. Do have means to hoist into a truck, etc.
Thanks Del
Thanks Del
