Dr John OConnor PhD
Pimp juice a Hemi's best friend
does anyone have images of the B&M bracket #10497 already attached to a 904 or 727 trans. No videos on youtube need a guide.
changing over from column shift to floor shifter do you have any images as a guide?If you get under there with the cable it’s actually pretty obvious how things go.
2 slightly longer pan bolts are a good idea.
Spacers go between the cable bracket and the pan so the bracket clears the pan lip.
The normal bolts are a bit short for that.
WHAT IS THAT SUPPOSED TO MEAN?????I don't have a PhD
