[WANTED] 727 auto slip yoke.
440DART1970
1970 Dart 446ci Swinger
NJ
In search of 727 torqueflite slip yoke 30 spline.. I'm not really sure of all of the grades but I believe a 7290 is what I need or better
The 7290 is the large U-Joint application. The 7260 is the small U-Joint. I have one for the 7260 joint.
Ken
Edison, NJ
Another 'half the story' reply. Dudes, the cap size is the issue, and the fact that the 1330 1350 series uses an external snap ring retainer. Your U joint on drive shaft ideally should match the yoke arrangement. There are unequal Cross joints, but keep it simple.
So I guess staying with the 7290 which is the big yoke from Factory will be the way to go
