727 band strut install
Transmission and Drivetrain Tech
  1. coro500net
    coro500net Well-Known Member
    100
    3
    Oct 15, 2008
    Local Time:
    2:59 AM
    I have a fresh rebuilt transmission on my bench and I put an A&A valve body and low reverse servo. Took tail-shaft off to get to low reverse band lever pin out,everything worked out fine but I can’t get the band strut back in. Are there any secrets to reinstalling?
    Thanks!!
  2. Krooser
    Krooser Reform School Graduate
    2,852
    2350
    Jul 19, 2015
    Central Wisconsin
    Local Time:
    1:59 AM
    Did you back off the adjuster?
    • Like Like x 1
    • coro500net
      100
      3
      Oct 15, 2008
      Local Time:
      2:59 AM
      Yes adjuster is totally out.
      Are they supposed to just slide in or do you have to force it.
    • oldkimmer
      oldkimmer FABO Gold Member FABO Gold Member
      17,748
      5550
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      1:59 AM
      U have to push on the band with a screwdriver. Lay it in there and use another screwdriver to flip it in. Kim
      • Agree Agree x 1
      • coro500net
        100
        3
        Oct 15, 2008
        Local Time:
        2:59 AM
        I will give that a try
      • mopowers
        mopowers Well-Known Member
        5,223
        2285
        Feb 15, 2006
        West Sacramento, CA
        Local Time:
        11:59 PM
        Did you change the band? I only ask because they made solid bands with a couple different length lugs. The thicker lugs won't allow a strut used with the thinner lugs.
      • fshd4it
        fshd4it Squid inc FABO Gold Member
        372
        130
        Jun 9, 2016
        Winock WA
        Local Time:
        11:59 PM
        Yes indeed.
      • mopowers
        5,223
        2285
        Feb 15, 2006
        West Sacramento, CA
        Local Time:
        11:59 PM
      • 1994redram
        1994redram FABO Gold Member FABO Gold Member
        1,299
        719
        May 9, 2012
        Oklahoma
        Local Time:
        1:59 AM
        I wish I knew this about the bands. I was about to lose my mind trying to diagnose the issues on my freshly rebuilt 727. The band was adjusted properly by the builder. But started slipping in reverse after a few hundred miles. I attempted to adjust it, but I ran out of threads on the adjuster! I just didn't understand how or why...
      • coro500net
        100
        3
        Oct 15, 2008
        Local Time:
        2:59 AM
        Yes, the trans has been rebuilt and never installed. It was fine before I changed the servo. I’m sure something is just not lined up?
      • CudaFactHackJob
        CudaFactHackJob FABO Gold Member FABO Gold Member
        1,508
        564
        Mar 17, 2016
        Hemet, Ca.
        Local Time:
        1:59 AM
        Did you flip the anchor?
      • coro500net
        100
        3
        Oct 15, 2008
        Local Time:
        2:59 AM
        I’m sure the anchor is in right as you can see wear mark for the adjuster bolt. Is the band strut supposed to slide in easy or does it have to be forced in?
        I’m going to work on it tomorrow, I’ll let you know. Thanks
      • CudaFactHackJob
        1,508
        564
        Mar 17, 2016
        Hemet, Ca.
        Local Time:
        1:59 AM
        Not that; the long double strap that goes way up into the case. You have to push the band up in there to fit the strut in...BEFORE the drum goes in.
      • coro500net
        100
        3
        Oct 15, 2008
        Local Time:
        2:59 AM
        Ok I know what you’re talking about. I didn’t take that out I left the pin in the case just enough in the strap to keep it from falling apart.
        John Cope has video on you tube about changing the servo but it is tough to see how he got the and strut in.
