727 big block transmission lines
bbmopars
Nevada
What 727 big block transmission lines do you get for a 72 duster that has a big block 383&727 in it?Will ones from a 67-69 383 dart and cuda work?
I didn't have a good set for the 440/727 in my Barracuda so I "borrowed" the set from my wife's 1968 340/727 GTS.
Why not go with nickel coper and do your own lines however you want? 0 rust and easy to work with. AN fittings and hose is an option as well. Personally going with a combo approach with AN fittings and hose to give some flex points with nickel copper or stainless (still haven't decided) for my lines.
