............727 front drum.........
oldkimmer
Kindersley, Saskatchewan,
...........Total race 727 behind a 700 hp 470 stroker ......which drum is best......billet steel. aluminum, or alum with steel sleeve on it or is there something better than these.........this will be low 10s on engine and low 9s on spray............thanks...........kim.......
Go with the steel drum, and I believe that it is wider than the stock drum if my old memory serves me right.
Low 10s with 700 HP? Is that all?
..........I'm trying to stay outtta the 9s as it pretty expensive to race the faster brackets.........kim....
Aluminum with steel sleeve seems like best of both worlds.
The lighter weight will et faster and the steel sleeve you won,t have the aluminum getting in the fluid and the changes that go with that.
I wish someone would make a 904 aluminum drum with a steel liner.
Duane
