72Swinger360
Hey Guys,
I have a SB 727 here that I was told was a 72 727. The PO said the PK number id'ed it as a 72 trans. There is no partial VIN on the machined pad on the RH side of the trans(that would be way to easy!).
I need help confirming this trans as a 72 so I can use it for my 72 RR. It is currently missing its #'s trans and if this one is a 72 727, at least it will be the correct year.
The PK # is as follows- PK3640802 3989 5819
Any help with the ID or a good source for decoding the PK #'s would be much appreciated.
Thanks in advance,
Joe
Thanks in advance,
Joe
