A little background, rebuilt a 360 for my 1974 Challenger 360 and 727 auto. (I know not an A body but I have one of those also 69 Valiant) I'm posting here because this site has so much more traffic than for E bodies only. I was taking the car for a test drive on Friday and everything was running great, pulled the car into the garage shut her down and was checking everything over for leaks etc.. So wife calls and wants to have lunch at a local hamburger joint, get in the car fire it up put in gear and it will not move either forward or reverse. Feels like the trans shifter is not engaging the gears, anyhow put car in neutral and rev to about 3000 rpm for 20 or so seconds let rpm come down and put in gear and it moves. As long as I keep the converter loaded while driving it will drive but does slip if I step on it. So what is the consensus, Trans needs rebuilt, torque converter replaced, pull trans and rebuild plus replace converter. The trans was rebuilt 20 years ago when I first bought the car, torque converter is original equipment so the converter is 43 years old. Fluid level is good and does not smell burnt or discolored. Would it be worth a shot to pull trans pan and do a filter and new fluid? It did sit in the body shop for a little over 3 years not being driven, so I'm thinking maybe moisture is in the trans from condensation. Shot in the dark I know just don't want to pull the trans unless absolutely need to. Thanks in advance
Kevin
Kevin
