727 kickdown question
duster360
Alabama
I have all my kickdown parts except for the linkage going from the pivot bolted to the bellhousing to the lever on the trans. My question is:
Is that piece of linkage the same on all small block 727's whether it be a car or truck?
I can't say for sure but the 727 cases and where the kickdown linkage attached are all the same. So it should work as you are only dealing with the distance from the bell to the arm.
.........I know they r a totally different shape to clear the truck shift linkage....give it a try though as u have nothing 2 lose.....kim
