727 lokar kickdown cable installation help needed.
I am assuming that that is at an idol that quarter inch space between the little piece and the kick down teardrop is the way you're transmission likes it
car isn't running in the pic. yea it liks that space. i have an abody leaver at the trans so a longer lever may be adjusted different. has a very nice shift pattern where it is.
Whatever lever is on the kickdown at the tranny I measured the best I could and it seems to be one to one pull everything seems to be working as it should. Thank you
Easy. Junk the Holley and go back with Carter or Edelbrock.
i have question about the kickdown cable initial set up. I have a return spring at the transmission lever holding it forward as well as throttle return spring. I can move the transmission KD lever rearward about 1/2 inch before I can feel the internal transmission kd spring give resistance. I checked 2 spare transmissions and they do the same. Does this 1/2 inch travel get taken out before tightening the ferrule at the carb? I took it for a ride (A999) and it feels like it shifts way early to 3rd gear. Dogs on hill when moving slow.
Here's a Checklist:
....Carburetor opens and closes without any binding?
....At idle, throttle valve lever is forward?
....Carburetor opens and closes smoothly from inside and outside vehicle?
....Throttle valve lever on transmission is all the way back during wide open throttle?
I notice on my car that a very small adjustment in cable length changes the shifting point.
Shorter, faster harder shifts
Longer, slower softer shift points.
