Barrycuda Mopar Maniac Guru Joined Oct 5, 2004 Messages 333 Reaction score 3 Location Rosedale B.C Canada...EH Jun 7, 2013 #1 what is this in the white circle and what does it do I has a square head on the stud with a 3/4 nut
furyus2 Well-Known Member Joined Oct 30, 2010 Messages 2,420 Reaction score 909 Location weeki wachee fl Jun 7, 2013 #2 That is your band adjustment. Should be one on the other side of the trans too.
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,969 Location las vegas Jun 7, 2013 #3 furyus2 said: That is your band adjustment. Should be one on the other side of the trans too. Click to expand... that is the kickdown (1-2) band adjustment...the low/reverse band adjustment is inside the pan...
N nothingbutdarts Well-Known Member Joined Mar 16, 2007 Messages 3,935 Reaction score 829 Location Bailey, Co. Jun 7, 2013 #4 70aarcuda said: that is the kickdown (1-2) band adjustment...the low/reverse band adjustment is inside the pan... Click to expand... x2
