727 Roller rear planetary
AUSA66
Perth
Anyone used an A&A roller rear support & roller rear planetary in 727 the thrust bearing between the sun shell & rear planetary is roller when assembled there seems to be to much end play in the rear drum about twice did you have to shim or leave the original thrust washer in place between the Sun & rear planetary thrust bearing worried about the rear drum doing a wobbly dance when rotating
Have you called Rick at A&A yet? Sometimes he’s a little slow about it (most of the transmission innovators are), but he’s always gotten back up with me whenever I’ve called him.
I will give him a call when the holiday is over Cope is selling a lot of A & A parts as well
