727 transmission dip stick leaking help!
mopar951
murrieta ca
Hi I have a 727 trans I put the dipstick tube in put a new o ring added fluid now it's leaking where the dipstick tube goes In anybody had this same problem? I also tried different o rings also
Did you check the tube over real good for a crack. Sometimes they get stuck in and people Armstrong them out cracking the tube right at the O-ring groove. If no crack RTV or Right Stuff like Kim said
