Know it will,i was wonderin how much more? Like 8qts with the deep capicaty pans?View attachment 1715264010
It will take a little more fluid. Look for one of these under the hood, back by the fire wall.
I tried to say that but the op didn't pay any attention. If I would say 8 quarts and it only takes 6 then I'm the ***.Nobody here can tell you for sure, you have to figure it out for yourself. Start with 5or 6 qts and then warm it up, shift through the gears, and check. When you're close, drive it around the block and come back and check again. Level ground, in neutral. Then next time you don't have to ask the internet.
I heard if you have deep dish extra capicapty i here it alittle more then 6.your coolI tried to say that but the op didn't pay any attention. If I would say 8 quarts and it only takes 6 then I'm the ***.
I hear you ! Tried not to be a smartass. Maybe I'm just getting too old, but it really irks me when people turn to the internet, on certain things, without attempting to solve their problem logically first. How far off is it when the internet does all our thinking for us ??I tried to say that but the op didn't pay any attention. If I would say 8 quarts and it only takes 6 then I'm the ***.
The thing about this is that if you don't know what pan you have how are we supposed to know to answer your question correctly. "Every deep pan takes 2 extra quarts" is not a true answer.I heard if you have deep dish extra capicapty i here it alittle more then 6.your cool
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^Thats what the dipstick is for. It's your freind.
Never ever run a trans below the full mark. A little over is fine like half an inch or so. Some tubes get pushed down in further and put the full mark too low. Especially run it high for racing cuz the fluid goes to the back and the pump can suck air creating a 2-3 spin-up. It says Do Not Overfill..they mean by quarts.
I`m wondering about some of the info here too. I have never seen a filter imprint in a torqueflite or a tubo 350, or a turbo 400, all had deep pans with the appropriate extensions. Why run a deep pan if u are not going to use the extra fluid ? After it heats up, it will still be the same temp. !"I know the stock takes six" How do you know that? I have done probably several hundred transmission services on 727s and 904s and not one stock one ever took 6 quarts to fill. 4 and some change always did it. Where are you getting your information?
Directly from the factory shop manual.ever do ones with extra capicaty deep pans?"I know the stock takes six" How do you know that? I have done probably several hundred transmission services on 727s and 904s and not one stock one ever took 6 quarts to fill. 4 and some change always did it. Where are you getting your information?
No trash i did new gasket and fliter and fluid change.it was leakin so bad in the past.You’re saying run the filter as-is with a deep pan? How much trash is usually in your pan? 1/8” or something? With the correct extension the filter sits at the same level as oem. The top of the filter is also porous to allow flow. There is nothing to worry about.
