72Dart What douse this plug go to?
hoop
Kentucky 40862
What douse this plug go to, it has a brown wire & a green wire???
Its under the glove box in a 72 Dart, all heater stuff is pluged up
douse
   /daʊs/ http://dictionary.reference.com/help/luna/IPA_pron_key.htmlShow Spelled [dous] http://dictionary.reference.com/help/luna/Spell_pron_key.htmlShow IPA verb, doused, dous·ing, noun
verb (used with object) 1. to plunge into water or the like; drench: She doused the clothes in soapy water.
2. to splash or throw water or other liquid on: The children doused each other with the hose.
3. to extinguish: She quickly doused the candle's flame with her fingertips.
4. Informal . to remove; doff.
5. Nautical . a. to lower or take in (a sail, mast, or the like) suddenly.
b. to slacken (a line) suddenly.
c. to stow quickly.
Map light plug. Light itself goes under the dash near the upper door hinge. Should be a similar sort of plug near the e-brake handle for the switch.
map light is pluged up with a plug in with some pink wires & others as you can see in right corner of pic & the switch has a plug on left side.
ONLY YOUR WIRING DIAGRAM KNOWS FOR SURE.
Sure looks like a heater switch connector to me, but may be different on a/c vs. non a/c models?
