340plot
the bushy bush
I have here a 73 340 engine. It is a coplete engine minus the intake carb, manifolds,
the crank is perfect condition and it is standard bore.
The block is standard also.
This block needs a sleeve in cylinder number 2. I cracked it while taking a stuck piston out.
The rest of the bores are fine.
Also comes with heads,timing cover, harmonic damper, pullies,stock cam still in it, flex plate, 73 727 trans with converter. Both these are numbers matching to the 73 car i took them out of
id like to sell local, as shipping is costly.
I have no use for it, and i think 250.00 for all is a good starting point for someone looking to get their hands on a good buildable 340
located 30 minutes from martinsville international speedway in va
