[FOR SALE] 73 340 shortblock
gliderider06
Delaware
73 340 short block. Crank, rods, pistons. All standard bore and crank. The block will need 1 sleeve. Machine shop said .020 would clean it up, other than the sleeve. My plan was to go .020, cut down a 360 crank and turn it into a small stroker. I do have a fresh .010/.010 340 cast crank, that hasn't been used after turning. I also have a 360 crank I'll include if you want it that needs turning. So, 340. Spare (fresh) 340 crank and a 360 crank
Asking $450 for it all. I can not ship it and you need to pick it up.
Located in Milford, Delaware.
73 340 short block. Crank, rods, pistons. All standard bore and crank. The block will need 1 sleeve. Machine shop said .020 would clean it up, other than the sleeve. My plan was to go .020, cut down a 360 crank and turn it into a small stroker. I do have a fresh .010/.010 340 cast crank, that hasn't been used after turning. I also have a 360 crank I'll include if you want it that needs turning. So, 340. Spare (fresh) 340 crank and a 360 crankView attachment 1715688597
You sure I cant convince you to crate it up and send it via Fastenal to Texas? 78612 zip.
Eric
