RPM
Superior Member
Here is a decent USED set of upper door trim plastic off a '73-'74 Duster.
They are a little faded, but I am pretty sure with some good cleaning and some Armour All or something they would shine back up. Or even paint them again. They even have the lock ring ferruls in place. The screw mounting holes are damaged (like most) some of the center holes across the bottom will need washers ran behind the screws to hold them in place. The outer screw mounting on both sides is broken out (as with most). The simple fix for this is just drill plastic and door close to those areas and instll screws and reinforcing washers. (did it on my car and have no problems). They are not cracked or damaged anywhere you can physically see when installed. They are not sun-chalked either... just a tad faded.
$35.00 set and that INCLUDES shipping in the lower 48 (outside the lower 48 shipping will be calculated)
shipping out of Idaho
Paypal and money orders accepted.
Contact me through p.m. if you need them.
-RPM
-RPM
