DusterKrazy
I have a fiberglass hood to fit a '73-76 Plymouth a-body. I have thrown some tigerhair on a couple places in the top that will need finish sanding and it also will need some minor repair on the bottom side (rear brace under the very back of the scoop)- easily repairable with fiberglass cloth though. I don't want the headache of shipping this thing and risking it being broken on the way to you. These are around $550 new IIRC. I would really like to see $150 for it or close cash offer. No, it isn't perfect..but it's not $500 either!
It is drilled out for four hood pins and I believe you can bolt it on to your existing hood springs IF you get the LOW TENSION HOODSPRINGS!!
Located near North Wilkesboro, NC.
