73' B3 340 Duster pro touring build
You just hit it .....thanks Denny, your advice and knowledge are greatly appreciated !!!!!
You are making great progress there Ross. She is looking sharp. And a very proper salute to you.:coffee2:
I almost left today before correcting the flag.... But thought, oh crap I've got to change the flag before thunder sees the next set of pictures .
Todays progress.......Steering. Flaming River U Joints and Stainless Steel 3/4" DD shaft.
Impressive as always Ross. Glad to see the project goes on. One of these days I'll get back to the frog. Got a bunch of nice parts. Too many other obligations right now.
Those headers are insane! Not standard fitment I understand. Looks like plenty of steering shaft clearance too.
No skin off of his roof.
I usually check in here and then go over to the Babes and Bacon thread.
Make an evening of it.
Actually...they sort of are standard fitment for a B/E body with a small block, but I did remove the 3 bolt collectors and went with a set of Flowmaster Ball and socket collectors to gain some floor pan room.
Yes, there's plenty of steering shaft clearance as well as the starter.
Very nice. I bet I don't end up with that kind of room if and when I finally stuff the 440 into mine.:coffee2::salute:
Just start moving stuff around...like motor height and set back you'd be surprised what kind of room opens up.
Denny threw a fistfull of quarters into his engine compartment.
Only 3 or 4 of them fell out of the bottom onto the ground.
See you tommorow Ross!
Well for the first time the Duster is sitting on it's own suspension, looks like I need to raise the front about 1/2" and lower the rear 1" to adjust the Stance. HemiDenny and John (Old Man Mopar) paid me a visit to help get my front end squared away and kick around some future idea's.
looks like you did a little more work after we left.....nice
from the lowest point.....what kind of ground clearance do you have?
I had to see it on the ground but didn't measure the lowest point.....but the fender is now at 22.5" when we mocked up 2 years ago it was 23.25" so I probably will be raising it up some and the rear really needs to drop at least 1".
I can't get my pictures to post any bigger than they are so it's hard to see some of the details. WTF happened
I saw Scruffs messing with your camera.
According to the picture properties, it is set at only 500 x 335 pixels....Check your settings
