[SOLD] 73+ Center Link Wanted
roughidle
Super Platinum Member
Pennsylvania
I'm in need of an a body center link. Would prefer not to pay an arm and leg for it. Started reassembly with new pitman arm and idler arm and realized whomever wrenched on this K in the past retained older components instead of the proper steering linkage for the newer K... So long story short is I either get a newer center link or return the pitman and idler for newer ones.... Let me know if anyone has one they don't need. If it helps anyone out I've now got two 67-72 center links for sale or trade...
Thanks
Before you get too far off, here, check the splines on your box. (large / small) You have to have a pitman that fits the box. There is no "proper" linkage so long as the box, the pitman, the center link and idler all match.
What I meant by proper was that the "early" linkage doesn't match the "late" spool mount K frame. There was no box on the K, I had that seperately from years ago. The pitman I have does match the box I have. So, I do need a '73+ center link...
BUT... thank you for the concern; sincerely....
any of these look familiar?? Acquired these loose, from local yard clean out.
