73 dart swinger heater wiring
joshua dewitt
tucson, az
anyone have an idea what harness and wires are the ones for the factory heater controls, , the blower isn't working, and wanted to trace the power sources to what fuse area, I can see all good fuses, so? factory heat/ac car.. any ideas the core assy removed to be replaced, and reinstalled and plugged in no worky? wanted to check power and grounds but no idea where, too, manual doesn't show the heater or a/c wiring on wiring diagram I have...
What "diagram" do you have?
Go to MyMopar and download the two sections of the 73 shop manual, which, by the way, happened to get there from efforts on some of the guys here at FABO
Some of what you need MAY (in years past) be in the AC/ heater section of the book rather than the section 8 wiring diagrams.
Alert: The 73 diagrams are "different" and may be more difficult to follow. You can also download the 72 shop manual (also came from here, AbodyJoe) and leap back and forth, may make things easier to follow.
I can post little snips to help you along
http://www.mymopar.com/index.php?pid=31
http://www.mymopar.com/index.php?pid=109
One help on the 73 factory diagrams is to use the index, and the illustrated connector diagrams, which shows the shape of the connector, the wire color, as well as approximate location in the car
