[FOR SALE] 73 Dart Swinger
ddukeboy
Member
Saugus, California
Rating - 0%
0   0   0
I have a 73 2 door V-8 Dart Swinger. The 318 engine and trans are both original. I had a number of transmission leaks which prompted me to pull the motor to change the front seal. While the motor was out I freshened the motor with the following:
New timing chain
New gasket set, including head gaskets
New oil pump
New fuel pump
New valve seals
Rebuilt Carburetor (2bbl)
New freeze plugs
New plugs, wires, cap and rotor
New motor mounts
In fixing the trans leaks I replaced the filter kit, mount, shift shaft seal, kick-down seal and front seal.
I have also replaced the rear end (drum to drum) and the battery.
She needs a little body work and a paint job but runs great.
I am located in Santa Clarita Ca 91351 just 40 miles north of LA.
I am asking $3800
Nice car, Man!....Where's the steering wheel?, I don't see it in the pic, does the car come with a steering wheel?:confused:
Steering wheel costs extra, they don't come cheap. I was actually trying to take a pic of the miles which shows a hair under 66k.
So I had some body and paint work done on the Dart and wanted to put up some new pics. The price is now $5000
